fault code 1111
fault code 1111
HI every one
I am registering one fault code:
1111 (Blink Fault Code), VAG1551/2 Fault Code Number 65535 Engine Control Unit (ECU) Defective memory circuits, incorrect Checksum for EPROM(s) (this can occur on some modified ECU's) Check ECU ground connections, Replace ECU?
Is this true about modified ecu's? That they can pop code 1111. I don't know if my ecu is chipped or not?
Any help is appreciative in the path that I should check to correct the problems.. I am searching hard.. but I will take what I can get.
Thanks
Josh
Thanks
Josh
m4rcus?
09-14-2002 12:58 PM
mfjp
06-15-2001 06:45 AM
donp
06-11-2001 07:36 PM
