front axle torque specs needed
Replaced my front left axle last night as the outer boot had completely torn away.
I searched the forum, and Dave had sent a diagram showing the outer bolt at the wheel hub to be torqued to 148 ft-lbs.
I am needing the torque spec for the axle flange to transmission.
There are 6 hex head type bolts at this joint.
TIA
93s4
TIA
93s4
Replaced my front left axle last night as the outer boot had completely torn away.I searched the forum, and Dave had sent a diagram showing the outer bolt at the wheel hub to be torqued to 148 ft-lbs.I am needing the torque spec for the axle flange to transmission.
There are 6 hex head type bolts at this joint. TIA
As for the six small triple square head bolts that hold the inner CV joint to the transmission drive flange, they are N 90668201, M10 x 48. Their proper torque is 80 Nm or 59 lb-ft (no extra stretch required for them).
Make sure you stretch that large bolt after you hit the 148 lb-ft.
Dh4lifenduro (06-28-2024)
ajg617
06-22-2014 04:22 PM
Worldwidebeagle
Audi allroad
01-26-2014 08:13 AM
gersting
11
02-02-2008 08:05 AM
RussB
03-28-2003 05:47 AM
