Front Passenger CV Boot repair tomorrow - what should I look for when inspecting CV Joint ?
I'm new to CV / Axle issues so bear with me: what should I be looking for to see if I need more than the CV Boot Kit ?
The car has 190K and I wonder how long the CV joint & wheel bearing will last ?
One:
Remove, clean, and inspect the joint prior to re-installation
Two:
If the grease is still clean and the joint is quiet, add some new grease and re-install.
I used to be a "one" but now I'm a "two". Tearing the joint apart almost is a messy job, and you will almost always find some pitting. Now I pull the joint, wipe off the grease, squirt new grease into the hole that the shaft goes in until it is full, then re-install.
Two:
if it is making noise, you are too late, otherwise, refill and go. A CV will almost never go out as long as it has greese and is kept clean.
and wonder if I should be selecting vendors for CV Joints and Wheel Bearing replacements - given it's a 190K high-mileage, car I have no experience with timing the rep. of these axle related parts.
I guess when you say "CV joint noise" you are not talking about constant noise, but the clickety-click or clunking sounds esp when turning - right ?
If quiet- as others have stated - CLEAN is the order of the day. As your boot is torn - assume dirty. No matter how clean it looks.
