Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Fuel Surge Tank - Swirl Pot => HOW TO? DIY?
Old 01-12-2009, 09:22 PM
  #11
SilberUrS6's Avatar
Default Wow.
That means the 044 can deliver a LOT of fuel, since volume increases as a cube function of tube diameter.
Old 01-12-2009, 10:02 PM
  #12
Former Vendor
nate @ 034MOTORSPORT's Avatar
Default We've run single 044 setups on cars with 750whp before. So yeah, they're a badass pump :)
Though we strongly encourage dual pumps at those levels!
Old 01-12-2009, 10:21 PM
  #13
J@RO's Avatar
Default Dave - Hap's car is phenomenal - no? :] Hahaha Sorry - 'Me Kan't Read' ;)
Quick glance just was not enough
IM SORRY CAPTAIN (:]) HAP - you're my idol.
Old 01-12-2009, 10:27 PM
  #14
J@RO's Avatar
Default Incredible that you can achieve such a good output for so little money. 044 goes for like 300+lines
Nate - so whats the construction of the fuel lines of a 500+ WHP car?
I assume that its some sort of rubber hose with stainless reinforcement - no? Or is it solid ?
What kind of pressure is that? like 40-50 psi?
Whats reliability of a 044 powering a 400+whp car?
Old 01-13-2009, 09:00 AM
  #15
Former Vendor
Default In the kit we have for the UrS it's -8 braided stainless line for install simplicity.
It could be done in hard line as well, but takes much longer and a bit more tooling to do right.
Line pressure depends on FPR pressure and boost levels. UrS cars start at 4bar (58psi) and rise with boost pressure to keep the pressure differential across the injectors the same. So if you're running 30psi of boost you'll have 88psi of fuel pressure from the pump to the rail.
As for reliability, these are pretty much the industry standard race series fuel pumps used by tons of top teams for nearly every form of racing out there. They've got arguably the best track record of any pump I can think of off hand.
There is a Bosch step up from the 044 though, the 413 pump. It's basically an 044 pump that tested out at a higher capacity and pressure rating than the normal 044s on the production line. So those get yanked off the normal line, get a little more special care, and a price tag 2x as high stuck on them
I'll try to get some shots of the kit up on the website today for you guys.
Old 01-13-2009, 10:44 AM
  #16
germantoy's Avatar
nates right hard line is a pita compared to braided. are you guys using a different fpr? and rail?
Old 01-13-2009, 11:37 AM
  #17
Former Vendor
Stock rail and FPR setup.
budavid
06-08-2009 03:41 PM
A8CT
12-07-2008 01:33 AM
mAgnum8
10-18-2008 06:10 PM
Khuram
02-26-2005 06:15 AM
piercejr
Audi 100 / A6 (C4 Platform)
09-02-2003 05:14 PM
Quick Reply: Fuel Surge Tank - Swirl Pot => HOW TO? DIY?
