Help - blown ECU fuse now running real rough
I blew the ECU fuse this morning - the 15amp that sits above the ECU and car died. It came on as a sudden failure while driving down highway at 70mph.
After replacing the ECU fuse the car started right up but runs very rough like it is running on 4 cylinders. Any ideas???
Could I have blown a coil that caused the ECU fuse to blow and now the coil is shot???
TIA
TIA
Took the coil cover off last night and the #2 coil had some goo leaking out of it tnd ther was a smell of burnt plastic. Did the POS switch and dead cylinder stayed on #2 so looks like #2 coil shorted then went open circuit therefore ECU fuse stayed intact and car could run on 4 cylinders.
Now I need to find source for coil or look into the 1.8T conversion - any suggections?
