Help!!! removing the interior door panel on the front pass. side.
My lock mechanisim is wonky..But I don't know the correct way to pull off the door card..
Any help please?
Thanks!
I have already removed the pull handle.
Any help please?
Thanks!
<center><img src="http://www.anyboard.net/gov/mil/anyboard/uploads/C4_A6_front_door_card.jpg"></center><p>I've never dismantled the door either.
<ul><li><a href="http://www.carstereoremoval.com/htm/stereoremovalAudiS492_93P.htm">http://www.carstereoremoval.com/htm/stereoremovalAudiS492_93P.htm</a</li></ul>
Near the top, front and rear, you'll see two exposed screws. Remove.
Now, the insert a butter knife or thin flatblade between the two halves of the grab handle and the bottom will pop off. Remove the two exposed screws and remove the handle.
Now, the door handle will slide backwards (or forwards, hell I forgot), remove it (IT pulls out), remove the metal clip securing the cable, pop the cable off the handle and then remove the hook end of the cable from the handle. Remember the way it goes on. Unplug the switch from the handle and remove the handle. Now, the front black trim piece will slide off too. There is a hidden screw right around the door handle area. It's under the black plastic insulation, and can be hard to find. Once it's removed, the panel will slide up and out.
