Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
hey crapple, did you follow the direction in the 'tech' part of this site for hardwiring the V1?
Old 04-05-2005, 04:13 PM
90sportin's Avatar
Default hey crapple, did you follow the direction in the 'tech' part of this site for hardwiring the V1?
seems prety easy procedure by that guy's article
Old 04-05-2005, 04:46 PM
Junior Member
NotCrapple's Avatar
Default no. haven't even seen it.
the biggest pain in the *** of the whole procedure was in the front left corner, fishing that wire next to the windshield is near impossible. luckily i have an a-pillar boost gauge, so i just ran the wire behind it, and noone can see the sloppy corner-cutting i had to do.
also a nifty little trick you can do to keep the wire in the headliner -- take some masking tape, and roll a cylinder, sticky-side-out. make it small enough to squeeze between the glass and the headliner, but big enough not to fall out.
Old 04-05-2005, 05:34 PM
tpierce's Avatar
Default Re: no. haven't even seen it.
also, if you gently pull on the front of the headliner (by the windshield), you can feel it come down a little. I tucked the wires up there, put the extra stuff on top of the panel with the control for the moon roof and had the wire exit the headliner by the windshield. These cars are nice because the V1 fits almost perfectly above the rearview mirror and below the headliner (mine does anyways.)
Old 04-05-2005, 07:57 PM
90sportin's Avatar
Default I'm scared that mouting it there, above the rearview, will block the rear sensor on the V1
Have u had trouble with that?
and if you look at that tech article on hardwiring a v1, its super easy to do. took about 30 minutes to hook it up and looks great.
Old 04-06-2005, 07:14 AM
tpierce's Avatar
Default i can look in my back window and see the sensor,so i guess it can see out
it does pick up stuff
boricuaA3
Audi A3 / S3 / RS 3
04-19-2007 04:10 PM
evils4
15
02-29-2004 07:49 PM
RMcQ
Audi allroad
06-20-2003 01:05 AM
Fenian
05-09-2002 06:16 AM
adammorley
11-25-2001 06:07 AM
Quick Reply: hey crapple, did you follow the direction in the 'tech' part of this site for hardwiring the V1?
