How do I remove to the instrument panel?
The first thing to extend the Steering wheel all the way back and down. Put a towel on top of the plastic steering wheel bezel (to prevent scratches). The next thing to remove is the black strip/ledge at the bottom of the plastic "glass" on the Instrument cluster. There are two screws (access from the bottom of the strip). Remove screws and pull the left end of the strip towards you. There are two (one?) pins on the right side of the strip that will form the pivot point. When the left side is out far enough, push the strip towards the left and the right side will come free. Then it is simply a matter of removing screws and connectors (as you pull the cluster free). Like I said, that was from memory, so there may be something I forgot.
Dave F
Dave F
Or here is the direct link:
https://forums.audiworld.com/a6100/msgs/22219.phtml<ul><li><a href="https://forums.audiworld.com/a6100/msgs/31818.phtml">Please check the 100/A6 FAQ for answers</a></li></ul>
<center><img src="http://www.anyboard.net/gov/mil/anyboard/uploads/dashnight.JPG"></center><p>I'm sure that no one will buy my car now.
