Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How do I remove the X-plug on the power steering pump?
Old 07-02-2006, 11:46 AM
S4orceaudi's Avatar
Default How do I remove the X-plug on the power steering pump?
Need to replace mine due to a leak, does it just screw out or is there more to it?
Thanks Rich
Old 07-02-2006, 12:41 PM
20VT90q's Avatar
Yep, it just screws out. However, the x plug uses an x socket attachment to remove it.
Old 07-02-2006, 01:07 PM
Hoog23's Avatar
Default Re: How do I remove the X-plug on the power steering pump?
I think you really need a air impact wrench as well as the special napa fitting.
I just had my mechanic do it with the impact wrench.
Old 07-02-2006, 01:16 PM
quattro20v's Avatar
Default You will need a drag link socket, Sears sells them.
You may have to grind it down a bit to get it to fit. Snap-on sells them too.
Old 07-03-2006, 04:46 AM
New Member
cashguzzler's Avatar
Default Here's my cheapskate method...
Go to the hardware store. Buy a punch or similar device (a file works as well). Then use a grind wheel to grind the tip of the punch so that it fits the X-plug just as a flathead screwdriver would fit a screw.
Total cost to me: $6.
Trip to hardware store: 20 minutes
Time to swap-out X-plug: 5 minutes
Easy as pie. Clearly, it's only a good idea if you have a grindwheel or something similar.
Old 07-03-2006, 06:52 AM
Wahhab's Avatar
impact wrench did it 2 days ago. It was slipping out with the ratchet
Old 07-03-2006, 04:15 PM
kday's Avatar
Default I was even more of a cheapskate...
I used a flat screwdriver at an angle and pounded it with a hammer.
Ugly, but it worked in a pinch.
Old 07-03-2006, 04:18 PM
Bill the Cat's Avatar
Default Here is my file - works great!
<center><img src="http://pictureposter.audiworld.com/60384/x_plug.jpg"></center><p>As you can see - it is a fine bastard (#2 - I think) that the wife's ex left behind. (Another bastard...)
Old 07-05-2006, 12:21 PM
escargot's Avatar
Good story.
Zumkopf
09-10-2015 05:23 AM
ledzepp2994
05-29-2009 08:41 AM
jguthrie
07-25-2006 09:13 AM
badomun
16
01-31-2005 02:38 PM
Quick Reply: How do I remove the X-plug on the power steering pump?
