How do remove cam sprocket? Do I need the locking tool? (for CPS replacement)
For those that think this is sacrillege... keep in mind there is no VAG crank lock tool on the B5 V6. There is only an VAG tool to lock the Cam sprockets allowing the Crank pully bolt to be removed i.e. only the timing belt tension to hold the pulley in place.
I had a t-belt blow up on my 8v VW 4cyl, and that was expensive enough to fix with only 4 bent vales. no way I'm risking this motor!
Audi-Impaired
03-30-2003 08:32 PM
GrandPaJohn
11-11-2002 09:39 AM
