Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
How many hours of labor for a "good" shop to install clutch/flywheel?
Old 11-19-2007, 10:22 PM
  #11
MiniMan's Avatar
i think it is. it took the local indy shop between 11-12hrs each time it was done.
Old 11-20-2007, 04:52 AM
  #12
1stturbo's Avatar
Do you have to crawl through the ski bag to get out after you drive in there?
Old 11-20-2007, 06:09 AM
  #13
repeater's Avatar
Default I'll tell you, it was one of the easier transmission jobs I've done.
There were a couple hang-ups that took a long time. First of all, the shifter linkage removal, installation, and adjustment is a colossal bitch. The transmission doesn't have enough movement to allow you to totally remove the linkage before you drop the trans, so you have to drop it halfway, tweak the hell out of it, and then remove it. Other than that, I thought the general process of getting to the bolts, driveshafts, etc, was one of the easiest, most straitforward transmissions I've done, it's just because there's so much to do, it's time consuming. I did mine on the ground too, if it makes a difference. With taking my time and doing suspension work (took the struts out, powdercoated the assemblies and changed springs) and some other fun things, it took about 14-16 hours.
Old 11-20-2007, 07:49 AM
  #14
kday's Avatar
Default Let's just say it's a good thing I don't have an especially wide physique :)
It's just barely wide enough to change tires on both sides of the car, <a href="https://forums.audiworld.com/s4s6/msgs/169640.phtml">but it's a bit tight</a>.
But hey, it beats working outside.
Old 11-20-2007, 07:53 AM
  #15
kday's Avatar
Default It was way easier than this A6 motor swap though!
With the passage of time the clutch job doesn't seem like it was that bad anymore. Funny how that works...
kharmA4
New England Discussion
11-08-2007 06:10 AM
sbmellen
04-12-2007 10:04 PM
spawt
09-08-2006 07:39 AM
SparTTan
Chicago Discussion
11
05-18-2006 05:44 AM
greenapple
06-08-2004 04:02 AM
Quick Reply: How many hours of labor for a "good" shop to install clutch/flywheel?
