Hypothetical brake bleeding question
If you were pressure bleeding your brakes and the plastic bottle blew off the master cylinder, that means you'd need a whole new assy, right?
The reservoir has o-ring seals and it just pushes onto the top of the master cyl. You should be able to push it back on or just replace the o-rings. I've never had a problem pressure bleading, but I never go over 25 psi. At what pressure did the blow off hypothetically happen?
spiralsmurf
Audi Original "S" Cars
10-06-2005 11:28 AM
bretto
06-12-2002 12:37 PM
