Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
I was out road-testing latest software drop from Mihnea (THANK-YOU !) and this guy pulls up
Old 03-08-2006, 01:08 AM
Guest
VR_Life's Avatar
Default I was out road-testing latest software drop from Mihnea (THANK-YOU !) and this guy pulls up
next to me and says "Hey, what are you doing?". I was in the middle of cursing the recurring throttle cut bug which still plagues me :-/ But I thought the outline of the door and handles looked familiar... I look closer ... he's driving a 93 Pearl UrS4 !
So we got to chatting ... he has a full RS2 conversion. I explain I'm doing data logging on my latest GT3071 software drop.
So we do some highway speedo calibrations, my timing is teh suck but I still pull away nicely ;-)
We swap cars, and I got to drive an RS2 conversion for the first time. It's nice, very smooth like stock, but kicks in later i.e. more lag. In the end I'm so glad I got to ride an RS2, because now I really appreciate what I have: GT3071 is a torque monster !
And surprise : his car had the exact same throttle cut issue in 2nd gear at ~4K rpm, and I notice his Wastegate spring has been hyper tightened. . . hmmm
2nd surprise : he's lived only a few hundred yards down the road from me the entire time...
Old 03-08-2006, 07:16 AM
spiralsmurf's Avatar
so you think the gt3071 has less lag than an RS2 turbo? makes me rethink my gt2871 plans
Old 03-08-2006, 07:25 AM
Member
Only-Emre's Avatar
Default It's been said the GT2871 has lag similar to K24, flows to 400chp, but tapers off up top.
The GT3071 has lag a bit less than the RS2, flows to 450chp, holds steady up top. The Gt30R has more lag then the rest, flows to 550ish chp, and CAN boost 45psi.
Old 03-08-2006, 07:45 AM
ThetaTau87's Avatar
Default Does the RS2 conversion have more lag than stock or more lag than gt3071?
It sounds like you meant that the RS2 has a bit more lag than stock. How does the lag of the RS2 compare to the gt3071?
Old 03-08-2006, 08:47 AM
germantoy's Avatar
Default that is EXACTLY correct i dont know why one would go with the 2871 when our cars breath so nicely up
top
Old 03-08-2006, 09:32 AM
Guest
VR_Life's Avatar
For *the one I drove* RS2 lag > GT3071
Old 03-08-2006, 09:46 AM
Guest
VR_Life's Avatar
I'm expecting GT2871 will have *less* lag than a K24, and more top end than an RS2 = wild !
Old 03-08-2006, 05:46 PM
MiniMan's Avatar
Besides the ARP studs and the metal head gasket, any other engine work to your car?
Old 03-08-2006, 10:31 PM
Guest
VR_Life's Avatar
Default No porting work, cams or stroke/pistons if that's what you mean
I installed a reconditioned head/valves. But the only flow changes have been from Phenolic Intake spacer, Polished & Coated RS2 EM.
Old 03-09-2006, 05:17 AM
MiniMan's Avatar
Default The reason why I ask is because I'm curious as to how the the pistons/rods are going to hold up...
That's a lot of power to be putting through 'em!
Quick Reply: I was out road-testing latest software drop from Mihnea (THANK-YOU !) and this guy pulls up
