I stfa'd, replacing passenger's window switch
Need a nice dumbed down version of how to replaced the passenger's side window switch.
thanks in advance,
Andrew
thanks in advance,
Andrew
1. Pop off cover at front of armrest by inserting a small flat blade screwdriver into the hole at the bottom
2. Unscrew front of armrest (Phillips screws) and remove it
3. Loosen trim piece holding switch and disconnect switch
4. Take the trim piece with the switch inside your home, and pry on it and curse at it for a while until the switch finally comes out
5. Put the new switch in and put everything back together
I think the driver's side is a bit more complicated.
Maini
07-14-2008 10:53 AM
s4sd2007
01-07-2008 07:33 AM
