I think I have a bad coil/POS
My symptoms are a sputter at fullish boost. Stops when I let off. The sound is like a "farting" sound out of my stromung- (lack of better words). The sputter is constant- until I let off.
Does this sound like a bad coil or POS?
that I got at Autozone and it led me to the third coilpack. Its probably a coilpack causing the problem as I was told they will often first show symptoms under load....good luck!
Basically you test each coil. All will test out OK. But if you test them repeatedly while gradually widening the gap on the tester each round, eventually one will fail.
Unplug the fuel pump relay or fuel injectors before you begin.
