I think i need a new rear diff
There is a horrendous clunk emanating from the rear when shifting and tremendous slack in the entire driveline. All of this after tranny/engine mounts, snubber and rear diff mounts have been replaced, some multiple times. I've r&r'ed the center shaft as well. I'm starting to think there's play in the rear diff between the input shaft and the two axles. I'd love to pop a torsen diff in there but if I can't find one, no big deal. Where can I find a good used rear diff? Thanks!
Rokas
95.5 S6
Rokas
95.5 S6
Same happened to me, the clunck, etc.
See attached photo from this post, you need to change the bushing in the cross member bar part #5.
This bushing has open space above and below, most likely it sheared away and the bolt is hitting the top of the crossmember.
Take a flashlight under the car and take a careful look...<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/179575.phtml">https://forums.audiworld.com/s4s6/msgs/179575.phtml</a</li></ul>
But the clunk was each time I let out the clutch was the bolt for the bushing hitting the crossbar.
rakta *chchchanges
12-24-2008 06:13 PM
UrSoccer_mobileĀ®
01-29-2004 09:31 AM
Mr.FRU-T-Pants
Quattro: Turbo / Ur / Sport
12-14-2003 08:07 PM
moribundman
12v V6 Discussion
08-27-2003 05:52 PM
