injector recomendation??
witch injector you guys recomend.(stock intern) ive got 044 bosh fuel pump,fuel preshure regulator,034 down pipe ,header,gt 30 71 turbo ,stage 3 ,chips,fmic,azot sprinkler,ect . i was running litle bit lean last years with the rs2 injector(replica)
could be a plus for you.<ul><li><a href="http://www.racetronix.com/621037.html">http://www.racetronix.com/621037.html</a</li></ul>
remaping i was thinking that those mrc chip sets was preset for a certain boost and the motronic still adjust timing /fuel/ ect ,when you run biger injector?
i did run them last summer it was ok but it was lean little bit! my english it not so good so you did misunderstand me! i have mrc chip set stage 3 and i want to no if the motronic stil modified the timming/fuel/boost if i go litle biger on injector
With some injectors there's the possibility of significant variation from one to the next which could have a big effect on tuning - since we typically don't have a WB 02 sensor for each port.
I wouldn't buy anything that didn't have fuel-flow documentation for each injector. I found RC (Russ Collins) Engr had the tightest numbers, and they flow every one. Spendy though.
DAP@EPL
51
03-20-2006 08:33 PM
cpayne
Audi Original "S" Cars
06-15-2005 09:12 AM
2low4snow
12-04-2004 04:58 PM
jlh28athome
01-11-2002 07:05 AM
