Injectors electrical plug in front. Damaged by engine heat? Where do we get replacement for this
<center><img src="http://pictureposter.audiworld.com/105658/new_chips_wires_070.jpg"></center><p>harness, or do we just change the plastic piece. Any ideas
<center><img src="http://pictureposter.audiworld.com/105658/new_chips_wires_068.jpg"></center><p>
and normally not a separate replacement part.
However, it is available. Just requires buying Kate a nice dinner and a movie first to soften her up.
The female harness plug is 443 906 233.
Next time, take your screw driver out of the photo. It hides too much and adds nothing.
<a href="http://smg.photobucket.com/albums/v48/chrisanjenn/Audi%20S4/?action=view¤t=IMG_1253Medium.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v48/chrisanjenn/Audi%20S4/IMG_1253Medium.jpg" border="0" alt="Photobucket"></a>
Plug is the same as a knock sensor on a VW/Audi/BMW, quick junk yard dive should yield
a cable you can splice onto the end of your
CPS.
BUT
You might want to consider replacing the CPS
sensor while you're at it.
I do have a couple cables, I can give you one
if you can't find one.
CPS.
BUT
And when you get to know Kate, maybe you can find the part numbers instead and I can criticize (sp) you for taking more than 3 minutes.
