Just replaced my valve cover gasket a month ago..
and it's leaking again on teh backend passenger side corner.. Since the gasket is fairly new, can I reuse them after cleaning eveything again? Do I need some sililicone sealant or so?
TIA
TIA
the back passanger side is where the rubber plug is isn't it?I put a layer of RTV silicone the whole way around my gasket, and the plugs.
I reused mine, afer fixing a small leak at the rear of the head. The leak often comes around the half-moon shaped plugs. The trick, from my mechanic friend, is to put plenty of silicone on top of those plugs and in the plug recesses. Also make sure the gasket doesn't shift in its recesses as you put the cover in place prior to torqueing the bolts. My cover is dry and tight now.
Pavoldoe
A4 (B7 Platform) Discussion
04-15-2017 08:24 PM
UrSoccer_mobileĀ®
Audi Original "S" Cars
10
12-21-2004 08:05 AM
