Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Keyless Entry Reprograming... Forum Recomendation doesn't work.
Old 11-29-2006, 03:17 PM
c4S6's Avatar
Default Keyless Entry Reprograming... Forum Recomendation doesn't work.
<center><img src="http://pictureposter.audiworld.com/114659/img_6423.jpg"></center><p>
Okay, so I followed this description to reprogram the RF remote for my S6 to a T. New batteries installed and everything.
http://www.s-cars.org/postnuke/modules.php?op=modload&amp;name=News&amp;file=arti cle&amp;sid=211
This is the remote I have (see above).
What gives... the process sounded stupid. I have something else that says only the dealer can program it if it's the first time used with that car.<ul><li><a href="http://www.s-cars.org/postnuke/modules.php?op=modload&amp;name=News&amp;file=arti cle&amp;sid=211">S-cars.org - RF Reporgram Procedure</a></li></ul>
Old 11-29-2006, 03:41 PM
Audicted's Avatar
Default That is not the remote fob for a 1995.5 S6.
<center><img src="http://pictureposter.audiworld.com/5928/dscn0687.jpg"></center><p>
Old 11-29-2006, 04:02 PM
Audicted's Avatar
Default Here are the instructions
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/80163.phtml">Works for me everytime</a></li></ul>
Old 11-29-2006, 05:52 PM
Brdman*'s Avatar
Default This might work...
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/51803.phtml">Similar to Audicted's post</a></li></ul>
Old 11-30-2006, 02:48 AM
c4S6's Avatar
Default Re: That is not the remote fob for a 1995.5 S6.
This '95.5 stuff is making me nuts...
I was told this remote works for 1996-1998 Audi A6. I was told 1995.5 is really same as a 1996, but dubbed a '95.5 because of the OBDII issue (so they can't technically call it a '96).
This is the same remote my mom had for her '97 A6. My keyfob is FCCID: MZ2 410 819 4.
My car did not come with a keyless entry keyfob, like the one you pictured. I bought this one off Ebay, and was told it would work.
What is the PN#, etc for THIS remote (pictured)? What's with all this one year 95.5 stuff. It's driving me nuts!
I'm guessing these remotes are NLA from the dealer?
Old 11-30-2006, 02:50 AM
c4S6's Avatar
Default I'll try this tonight...
My keyfob is FCCID: MZ2 410 819 4 (as stated in that article).. But, I'm guessing now that my RF module is probably different and my remote won't talk to it.
I think the later cars can use anything, including the "switchblade" keys.
c4S6's Avatar
Mine won't unlock when I do that (does nothing).
Old 11-30-2006, 03:08 AM
Tech Guru
4Driver4's Avatar
Default You can buy the remote for around $100 from the dealer. They are on ebay sometimes too.
Programming sometimes requires several tries, but it takes forever if you use the wrong remote.
The remote pictured does not work with 1996 A6's either.
Old 11-30-2006, 08:40 AM
c4S6's Avatar
Default But, will my remote work with a '95.5??
But, will my '96-97 A6 remote work on a '95.5? That is the question.
If not, I guess I'm off to the stealer again (gasp!). I only need one remote, so maybe not so bad. Thanks for the info.
Do you have a Part# or UCC#?
Old 11-30-2006, 09:27 AM
Tech Guru
4Driver4's Avatar
No. You need the correct remote.
Quick Reply: Keyless Entry Reprograming... Forum Recomendation doesn't work.
