Locking system
Hey Guys,
i have a curious question, the central locking system in my S6 stopped working oh about a year ago or so. Never really looked into it much but the red light on the rear fog light button flashes when i click the lock/unlock button on the door or lock unlock with the key manually. Previous owner gave me two set of keys 2 for ignition 2 for the door locks. The key fob never worked since i bought the car and never really cared much since the 2nd set of keys worked to lock/unlock all doors through the drivers door.
My question is, has anyone ever heard or seen this happen before? and if so how to fix? do i have a leak? or is this more electrical issue?
ill be waiting to hear from someone...i hope![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
thanks gusy
thanks gusy
Hey Dave,
I'm not sure how to tell the difference, batteries are new now but I never really used it I used to manually lock unlock the doors with the key in the drivers door
The Infrared remote UrS6s a) have bumps on the side of the B-pillars (between the front and rear doors) and b) came on 1995 UrS6s, i.e. ones with the diff lock button in the centre console and the narrow (std. DIN) Gamma Bose radio.
The Radio frequency remote UrS6s a) have no bumps on the B-pillars and b) came on the 95.5 (and 96 and 97) UrS6s with EDL and no diff lock button, sidewinder keys and the wide-body Delta radio.
That help?
Once you figure it out, I will point you to the appropriate reprogramming sequence.
That help?
So that means you have the Infra Red type remote.
They use four Energizer 386/301 batteries, oriented as shown in the photo below.
Reprogramming the key, if/when required, involves have one key in the ignition, turned to ON/RUN (but not START) while the second key is used to manually lock and unlock the drivers door lock. If the car has been sitting for some time or you have to change the batteries, getting the remote to work again just requires that you lock and unlock the door manually once and then the key remote will "work" again. (The IR remote has a very limited range and is intereferred with by bright sunlight and fluorescent lights (e.g. in a parking garage). HTH
![](http://12v.org/urs/C4InfraRedRemoteKeyOpenToShowBatteries.jpg)
Sometimes the issue isn't batteries but the little Item 29 infra red bulb:
![](http://12v.org/urs/InfraRedKeyPartNumbers.jpg)
Good luck.
Good luck.
thanks Dave,
i tried that but didn't work. i think there is an electrical issue with the system. the red light that is on the rear fog light was lashing on Sunday like crazy. But it stopped the last two days and now the interior lights don't turn on when you open the doors.
they used to lol, I'm telling you there is a gremlin in the electric system for the central locking. ill do more checks once I'm back from Vancouver
thanks
thanks
