Maybe celebrated prematurely. The car just had a huge miss twice on second gear like it wanted to
die. I came back home and while getting ready to check for error codes motor died in idle. The error code showed 2111. I checked in the error chart shows it to be the rpm sensor. I think the car has 2 of them. I have to go to sleep and work early tomorrow. I guess going to have to wait to another day.
What is "a huge miss"? Skipping? Under load? All the time? Or is it a buck under load?
Did you check codes with the car running? If not, the crank position sensor will throw a code. POS and coil problems do not throw codes.
Just for information. As Tom says, usually, the 2111 code is thrown when the engine doesn't start. However, I do believe that at some point these sensors do indeed fail and the code is real. This may or may not be your problem.<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/116988.phtml">https://forums.audiworld.com/s4s6/msgs/116988.phtml</a</li></ul>
I restarted it. but it also missed twice big time as soon as I went from 1st to second gear.
chris43230
09-30-2008 07:23 AM
kinderutz
Audi 100 / A6 (C4 Platform)
03-10-2006 09:44 AM
