My clutch pedal dropped to the floor the other day.Can I confirm this is the slave master cylinder?
Driving to work, go to down shift and the pedal dropped to the floor, I managed to drive back home in second.
What else do I need to replace if any thing? Is this a sign of a worn clutch?
It's a guess - but the clutch? It still holds enough for you to put power to the wheels, so it's probably not the clutch.
BUT, since you're gonna be doing the slave anyway, why not replace the clutch, pressure plate and throwout bearing? Might as well finish the job you're gonna start...
i had a similar prob a year and a half ago replaced slave and the next day the master went. if one goes the other is sure to follow as far as clutch goes havent had to replace mine the slave and master wernt that hard to do the clutch is a whole diff ball game havnt done it nor do i want to you dont have to mess with the trans to do the other two
last as long as my aging clutch? I think a buddy and I can do the slave and master, but I dont want to mess with the clutch itself. I would let a mechanic do that.
if your clutch pedal feels heavy compared to other cars you drive, then it's likely that a worn heavy clutch killed your master cylinder, and replacing just the cylinder and not clutch only buys you a little time before you brake something else.
these are things you want to get new
