No power to fuel pump or starter.
My ignition switch failed and I was almost stranded. I installed a new one and everything except for the fuel pump and starter powers up. I thought I had gotten a faulty switch and replaced it with another new one. I still have power to everthing except for the fuel pump and starter. Does anyone have any ideas? Everything worked fine before the ignition switch failed.
Thanks,
Robert
Thanks,
Robert
obviously there won't be any cranking until the starter works.
<light bulb comes on>
Your failed switch caused the starter to stay engaged ALL THE TIME. Therefore, the starter is dead. (Has happened many times already with the switch failure).
Pull the starter and test on the bench. My guess is it's dead.
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/135837.phtml">click here</a></li></ul>
pipebender
01-01-2007 06:46 AM
Mr.88-80Q
12-09-2005 08:42 AM
