Noobie question...but still frusterated.
I was wondering if theres any trick to removing corner indicators... The right one was really easy, popped out, put the bulb in and fixed the new clear ones in. However, the other side won't budge. Is there a special trick for this or is it completely stuck. Thanks, noobie questions will stop soon dont worry
There should be just a clip you need to push down with a long screwdriver, then push the corner light out toward the front of the car. Be careful putting the new clear corners in however, make SURE the tab on the light clicks firmly into place, or you will one day arrive at a destination sans clear corner.
This is especially important with the Depo clear corners off eBay, in fact you may have to trim the tab just a bit to get it to sit correctly.
Look down from the top of the headlight, under the hood. You have to push the tab down to release - and on an S6 there's a little locking device that has to be undone.
If it still won't come out, just remove the whole headlight and the sidemarker will come out with it.
pimpyellowtt
10
06-21-2004 06:28 AM
shuto
05-02-2001 04:56 AM
