ok no boost problem
now i dont drive the car really but here is what happen..the car was fine till i added a cone filter and cleaned the isv..
when i start the car and hammer it i have boost but after that nothing till i restart the car..so limp mode of somekind..now could the cone or isv cause this? also can the isv be removed? like i have b4 on my corrado...
btw i always get surge out the cone everysnce i had this problem...wgfv? and no i dont have anyboost leaks
You probably have a boost leak of some kind. Did you mess with the bypass valve? The ISV is the only thing that keeps the car idling, so why would you want to remove it? If it's not a boost leak, then perhaps you damaged the MAF?
to the garbage.
I agree with Tim. You have a boost leak. The ECU senses overboost and puts the car into limp mode. Restarting clears it. Consider some upgraded (Samco) boost hoses..
how long you intend to keep the car.
He had posted about upgrading to a chip or more, so that's why I recommended the Samco's. Any idea what the cost difference is? It can't that much, can it?
has had no problems. However, his hoses are new or pretty new. I believe the MM is/was new.
i dont have a boost leak because i capped off both ends and filled with compressor and it hold 20psi with no drop...
i do this on my g60 corrado all the time to test for leaks
as for removing the isv i do this on my others to clean up the engine bay...all it really does is help control idle when a/c is on etc...many drill a tiny hole to flap to get a bit of idle air or crack the tb open a bit...i removed mine 5 years ago with my corrado and its perfect...i ask if it will work on audi because i dont want it to screw ecu..but being a output i say it will be fine...
no ididnt touch bypass valve..as for maf i dont see me damaging it all i did was install the cone to it...thanks a mill for all the replies guys
ePuFFy
02-15-2009 12:16 PM
PracTTical
09-28-2008 07:16 PM
econnelle
05-16-2008 07:00 PM
ThirdEye
03-29-2003 03:42 PM
