Out of curiousity, has anyone used ECS tuning's Camber plates?
ECS Camber Correction Plate Kit - Does Both Sides
Corrects out of spec camber on all "S" cars after the cars have been lowered,
Kit includes upper camber plates that reposition the starting point of your camber adjustment. Tyypically cars that are lowered are un-able to come back within factory specifications. ECS camber plates move the starting point of the camber adjustment in the position that is required enabling you to get the camber within factory specs. Kit also includes OEM/ECS spring perches are neccesary to properly install this kit.
*Requires modified spring perches & slight modification to inner fender lip where the upper strut mount comes thru the fender.
<img src="http://www.ecstuning.com/stage/images/dis/2435/600/2435.jpg">
<img src="http://www.ecstuning.com/stage/images/dis/2437/600/2437.jpg">
But in the end it seems like 2B is the best solution, despite the astronomical cost...Everyone seems to be happy with them as well. AMD's are just as expensive, and ECS's are $350 and not adjustable, and "require trimming". Not worth it IMO.
I have a set waiting for the Igor mod, which I might do until I can get a 2B set.
