P2227
Hi all,
forgive me for the rookie moves but this is one of my firsts posts.
I have a 2018 SQ5 with a 3.0t
The drive system has been showing a malfunction (the auto on/off for the motor at lights) and now it is showing this code p2227 and a vcds code of 18803 that is barometric sensor 1.
I have done a search and cannot narrow it down, hopefully someone can lead me in the right direction.
thanks!
thanks!
Tuesday,23,August,2022,20:22:32:56731
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.3.1.4 (x64) HEX-NET2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WA1C4AFY7J2089005 License Plate:
Mileage: 84945km-52782mi Repair Order:
Chassis Type: FY-AU49 (8W8)
Scan: 01 02 03 08 09 13 1516 17 19 29 32 36 39 3C 42 44 46 47 52
5F 6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
VIN: WA1C4AFY7J2089005 Mileage: 84945km-52782miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CWGD) Labels:. 06M-907-309-V1.clb
Part No SW: 80A 907 559 C HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0007
Revision: B2H22000 CVN: 2E89058E
Coding: 2A2A0032256E010E34280000000000000000000000000000
Shop #: WSC02391 785 00200
ASAM Dataset: EV_ECM30TFS01180A907559C 001008
ROD: EV_ECM30TFS01180A907559C.rod
VCID: AF30F9FEB7E015C3E65-81FA
VINID: 9D10531115A91DA0802090001422F718D2
1 Fault Found:
18803 - Barometric Pressure Sensor 1
P2227 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 84819 km
Date: 2022.08.20
Time: 18:39:26
Engine RPM: 543.00 /min
Normed load value: 9.0 %
Vehicle speed: 0 km/h
Coolant temperature: 99 °C
Intake air temperature: 62 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.640 V
Unlearning counter according OBD: 37
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0000 0000
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 84819 km
Date: 2022.08.20
Time: 18:39:26
Mike Freeman
13
10-29-2020 03:17 AM
Mooseposse
S4 (B8 Platform) Discussion
04-28-2020 02:47 PM
