preparing for S6 sport wheel swap into S4, quick questions and yes I STFA already
Gentz,
I'm getting ready to swap the S6 sport wheel into my S4, hoping I can pick your brain real quick. I have the S6 column with all the switches, the S6 clock spring and the S6 wheel.
Previously Weldon told me that I could just swap in the switches, and wheel with clock spring.
Don't I have to swap a couple wires? I've found the write up on cutting/gluing the clock spring, I would prefer to not do that if I don't have to, any input?
Thanks
Chris
Thanks
Chris
What you do is re-pin the A6/S6 colume switches, use the A6/S6 colume covers, & bolt on the S6 wheel. Done & over!
Now not sure the pin differences from a //s4 to a //s6..but thats what I had to do to put this stuff on my V8.
No need to cut/JB weld anything.
actual swapping of the pins.
If you stay with the S4 column, you need an adapter bushing because the inside of the S6 switches has a different diameter than the S4 column.
Personally, I bought all the S6 switches but decided it was too much work. Came up with "Method 2" and "Method 3". Steve Young did the write-up.<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/192798.phtml">Click here</a></li></ul>
The parts I described are exactlly what I used & it's a bolt on! There is nothing out of place with the install. The //s4 4 spoke wheel bolts rite on the V8...so why won't the way I did my V8's work on the //s4?
& the pin swap is prolly different for the //s4 to the V8 so I can't help you guys out with that. But as I mentioned every part bolted on as if it was the OE V8 stuff. I didn't need any bushing/spacer/anything....just the parts I mentioned.
I kow of @ least three V8 guys with this "mod".
Pin-outs are different. Bentley is incomplete and inaccurate to the point of being dangerous.
Needs lots of patience and trial and error to get the pin-outs correct for the swap. Dave Ellis from Audifans S-car list is going to document the pin-out and the connector PNs, etc.
V8s are closer genetically to the UrS4 than the UrS6 so I'm not surprized the swap was easier for you.
Aldo
01-25-2009 10:36 AM
ImQuattro®
Audi Original "S" Cars
04-28-2008 10:31 AM
