PS leak... found
PS leak... found
the pump is wet and the x-plug is wet as well there is a trail of fluid from the plug down the pump. i still cannot believe that this plug can loose this much fluid (drop from max line to min line in 10 days)
i have replaced the x plug gasket 2 years ago, but it never really stopped leaking, does the plug itself become bad too?
where can i get just the gasket? should i replace the plug too, where to find plug at?
i have the rebuild kit from Blau, but i already used the gasket from it last time (they would not sell the single piece)
thanks
thanks
You can't get just the O-ring AFAIK
Chefbob suggested to soak the O-ring in pentosin overnight before installing it. When I replaced mine without soaking it, the pump "rejected" it within a few tens of miles. I put the original O-ring back in for now but I have a new one soaking...
AUDIDOIT
Audi Original "S" Cars
15
01-15-2008 11:25 AM
Mr.D-'97 A4q 12v
12v V6 Discussion
07-13-2005 06:16 AM
