Question on Dave's boost leak test... (making sure i have a grasp on it)
So I just want to make sure i understand which end of the hoses to cap off of the 4 mentioned in the post by Dave.
1-Capping the turbo outlet hose. This would be taken off the turbo and capped so the air doesn't go into the turbo, right?
2-capping turbo to by-pass valve hose. This would be taken off the BPV and capped there? (this is where i think i made an error because the turbo wont have air in it if #1 is correct?)
3-Crankcase/camcover hose. Capping the end of the hose that goes into the back of the spark plug cover, yes?
4-capping ISV hose. Which hose would this be, the bottom hose, or the hose opposite of the ISV connector?
And do you guys cap the hoses same way you put the 3 inch PVC cap to pressurize the system, just without the nipple in? I know where to pressurize it from, im gonna make the pressurizing cap tomorrow i just want to make sure i cap everything correctly and dont hurt seals ect. thanks.<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/217734.phtml">https://forums.audiworld.com/s4s6/msgs/217734.phtml</a</li></ul>
Look at the diagram. You need to block off any connected to the hoses between the turbo and the
<center><img src="http://pictureposter.audiworld.com/52091/aanairflowdiag.jpg"></center><p>throttle body, that includes the larger inlet to the BPV (from the pressurized side) and the inlet to the idle stabilization valve, right near the throttle body.
ImAwesome
09-20-2006 06:43 PM
mbox
42
11-08-2005 11:43 AM
