Question regarding rear brakes (-95.5 S6)
I found out I have to replace both left and right rear brake calipers and pads.I have original calipers, discs , redstuff pads.
I`ll change the discs as well, since I am already on it.
Whats the best and most affordable solution?
I have EBC sport drilled rotors in the front.
Best regards,
Stephan, Norway
-95.5 S6 - a few mods, stage 2 chip++
Best regards,
Stephan, Norway
Just replace with stock (new or rebuilt) calipers and stock vented discs. Procedure link inside.
Most of the work is done by the front brakes so upgrading the rear brakes is not very cost effective. You can used slotted or drilled rotors but they will mostly be cosmetic not functional. Last time I did my rears I used PBR Metalmaster pads (but there are others out there).
HTH<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/149785.phtml">Rear Caliper replacement produre in the FAQ</a></li></ul>
Re: Buy new....
just replaced mine 3 days ago got the rear semi loaded calipers for 91 dollars a peice and the rotors i got from ecs for i think 120.00 for the pair slotted and drilled from ecs. did a fair amount of research and i will say that many people steered me away from the cardone caliper and when i actully saw one supposedly new in a box im glad i didnt go that route hope this helps
BSCA4
04-07-2004 11:21 AM
SLAB
10
02-28-2004 11:16 AM
Ernesto (ERT)
09-01-2003 11:06 AM
