Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Rear Sway Bars
Old 12-15-2003, 09:53 AM
  #11
AKrlic's Avatar
Default Re: The MTM "RSR" 20vt Coupe ran wider wheels and tires up front to...
Dave..tire adhesion and torque bias are two very different things, as I'm sure you're well aware.
Now, you can induce oversteer one of two ways... either by running a narrower tire in the rear, or by sending more power to the rear wheels. According to the fundamental principles upon which quattro operates, "torque is sent to the slowest moving wheels." Larger wheels spin slower, so they will always receive a proportionately larger chunk of the torque pie. again, the difference in the rolling circumference might indeed be negligible, but on a torsen-equipped car this might lead to accelerated driveline wear or even adverse driving characteristics. if anyone has any documentation on this phenomenon, please let me know.
if MTM weren't averse to disparate wheel/tire sizes, why should i be?
Old 12-15-2003, 10:31 AM
  #12
AntiSocial's Avatar
Default I had the plates put on my '94 w/HRSB
Easy install, best thing that happened to the car, handling wise. It drove so neutral with that setup (H&R/Bilstein, 28mm front, 26mm rear), but the big rear bar rubbed ever so slightly against the H&R springs. Rear coilovers will fix this. :-) No biggie, just a squeak every once in a blue and it wiped the powdercoat off the spring.
Old 12-15-2003, 10:32 AM
  #13
AntiSocial's Avatar
It's a conspiracy. =P
Old 12-15-2003, 02:16 PM
  #14
Kep
Member
Kep's Avatar
When turbo coming??
Old 12-15-2003, 02:24 PM
  #15
TurboJew's Avatar
Default Different width is not a problem. Rolling diameter must be the same though...
...in order to prevent long-term damage to the center diff.
Old 12-15-2003, 02:45 PM
  #16
AKrlic's Avatar
Default Re: Different width is not a problem. Rolling diameter must be the same though...
I'm running the same tires [255/35/18] at all four corners. Ok.. so..the wider width of the rear wheels will cause the rear tires to "stretch" to fit, in theory giving me a larger contact area in the rear.. but this same "stretching" [it's not really stretching, but more of a curving] will also leave me with a proportionate decrease in the measured "profile" of the tire. In other words, if you were to look at the car from the side and measure the profile of the tires with a ruler, you might find that the tires in the rear are "lower-profile", even though they are all the same size tire [i haven't done the math, but my logic seems cogent enough]. I believe it's this slight difference in profile which translates to a slightly different rolling circumference [which is where all of the trouble occurs, ostensibly].
Perhaps MTM ran a mismatched combo of wheels because their primary focus was on short-term performance gain.. maybe they knew this would ultimately kill the diff, but did it anyway because they can afford to. in this case, i'm ****ed [well, not really.. my stock wheels/tires are on right now], and i'm forced to sell my wheels at some point in the near future. OR, maybe MTM were enlightened on some higher mathematical **** [a euphemism, of course] and determined that the slight disparity in rolling circumferences were negligible. Who knows?
I've emailed a few people about this today... hope to have some concrete answers by the end of the week.
Thanks for the help, everyone!
Old 12-15-2003, 03:35 PM
  #17
urS4guy's Avatar
Default Answers
Guys
The answers to your questions are as follows. The mounting kit($150) will enable non-bar equipped cars to run this sway bar. For the guy wanting to know the benefit even if you run coil-overs, it comes down to comfort and streetability. Sure, the ultimate would be a track trimmed coil-over set-up but the drive on the street would be very hard(pun intended) to live with. I run 400lb linear Eibach springs at the rear and the feel is firm. I'm also running the bar at the middle, 140lb, setting. When I'm not in a turn, the bar is just along for the ride. Go into a turn and the bar prevents the outside suspension from compressing and the inside from decompressing. You'd need a much stiffer spring to accomplish this same thing and that would make your street driving uncomfortable. The bar also works for stock suspensions in the same way. The design criteria used by the Audi engineers was and is to give us understeer for safety concerns. A rule of thumb in suspension set-up has you going stiffer in the rear vice the front to diminish this understeer. This bar was designed to give us neutral handling at turn-in through apex with mild oversteer at exit and from all the accolades over the last 2 years we've hit it right on the nose. Another benefit is an overall stiffening of the car's feel. BTW we've done about 40 of these bars.
Hap, answerin in Everboost
Old 12-15-2003, 04:28 PM
  #18
germantoy's Avatar
Default I have this rear sway setup (thanks to joe) and well she loves it when i throw her in a turn...
no roll at all
i love it handles just like my rabbits of the past
Old 12-15-2003, 04:29 PM
  #19
germantoy's Avatar
Default hey god of all that i want to do to my car how did you get the rear big reds to fit?...
custom machine a bracket?
Old 12-15-2003, 06:19 PM
  #20
Former Vendor
Don@STaSIS's Avatar
Default Did the plates mount the subframe vertically or off the rear most subframe bolt, or something else?
Curious as to how the cars without the proper subframe fit the bar. I've been poking around at a '93 urS4 for a friend to do a rear bar solution and I suggested the Hap bar and he wants a stock setup. I don't want to swap subframes for him, way too much of a PITA, so wondering how that bar mounts, actually one of his questions as I tried to sell him out of the stock bar and stock subframe swap idea, a real pain in my *** if I have to go that route on that car. All I could see was to add a vertical bracket to the subframe slightly more inboards. Curious how the Hap bar does this, maybe I can sell this guy one so I have something easy to install
Thanks,
Quick Reply: Rear Sway Bars
