replacing injectors and MAF-----Anything to be careful of?
I assume this is an easy job. Just thought I would check before I brake something.
"research" at the same time. For you just unplug and replace. It's never a bad idea to disconnect the battery whenever you are working on a car. Remember your radio code.
1. Release the fuel pressure by slowly undoing the supply line to the fuel rail. Use rag to catch spilled gasoline.
2. Remove return line at fitting.
3. Remove black cover over fuel rail.
4a. Remove vacuum/boost line to fuel press regulator.
4b. Remove any crud lying around injectors, don't want it to fall into the intake manifold.
5. Remove fuel rail complete with injectors, I used a pry bar, a block of wood and a light hand to gently pry up on the fuel rail.
6. Take fuel rail back to bench and remove clips holding injectors in.
7. Careful, there is about 100 ml of gasoline in the fuel rail.
When replacing FPR, you dont have to take off the fuel rail do you? I was thinking just pull it off?
gohardRgohome
07-06-2008 02:42 PM
selfproclaimedv8buff
Audi Original "S" Cars
02-05-2005 09:48 PM
Julian_B
06-03-2004 06:00 PM
nanotech
05-23-2002 05:45 AM
