Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Should I switch to 10W40?
Old 12-16-2005, 02:53 PM
Junior Member
N'CTRL's Avatar
Default Should I switch to 10W40?
It seems easier to get than the 5W40 I switched to my last oil change. Also, since winter is coming up I thought it wouldn't be the worst choice in the world?
Old 12-16-2005, 02:58 PM
New Member
audi4k's Avatar
Default Re: Should I switch to 10W40?
I use a mix of 15w50 M1 and Castrol 5w50, that's becuase i wanted a better startup oil; however seems like even straight 15w50 wouldn't hurt. 10w40 shouldn't be a problem.
How cold does it get where you are?
Old 12-16-2005, 03:21 PM
AndreNY's Avatar
yea but 5W40 is so easy to get just order PENTOSIN that is OE oil for Audi/VW
Old 12-16-2005, 03:28 PM
kday's Avatar
Default 5W40 is a better oil for the cold than 10W40...
I'm not sure if you were suggesting the reverse or not. But anyway, I did not like the way my engine sounded at startup during the winter when I was using 10W30. Never tried 10W40.
The engine has never been quieter than with the Mobil 1 5W40 "SUV" oil I have in it now. It's smoother than with any other oil I've tried (15W50, 10W30, 5W30, all Mobil 1).
Old 12-16-2005, 04:33 PM
Bill the Cat's Avatar
Default Really makes sense
Fast lubrication on startup - holds it's viscosity when hot.
The SUV tag is a joke. (IMHO)(Well, maybe not - inferior pushrod engine - grossly overweight - the ultimate air dam. - Yeah - the lube needs to be pretty d@mn good.)
Old 12-16-2005, 05:06 PM
mtg
mtg's Avatar
Default I use 10W30 Mobil1 year round - no problems
Firm believer in Mobil 1 products for 30 years!
Mark near Chicago
Old 12-16-2005, 06:42 PM
WVUrS6's Avatar
Or Castrol 5W-40 BMW & VW "spec" available @ FLAPS
Old 12-16-2005, 07:03 PM
Junior Member
BlindBatForumFailer's Avatar
Default I used M1 15W 50 in philly year round...
What I use in SoCal now also... Turbo cars like thick oil.
Old 12-16-2005, 09:46 PM
Guest
VR_Life's Avatar
Default Also available as Delvac1 5w40, which is available in bulk and cheaper (it's used by truckers)
The contents of the bottle are identical
Old 12-17-2005, 07:07 AM
TabulaRasa's Avatar
I'm running Shell Rotella T 5w40 synthetic made for diesel semi trucks.
Quick Reply: Should I switch to 10W40?
