Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Should my coolant boil?
Old 04-09-2009, 01:29 PM
  #11
Sloooo4esT's Avatar
Default after a couple minutes the level would go back to normal, mechanic said he's seen it
happen before, said the pump spins so fast the coolant cavites
Old 04-09-2009, 02:11 PM
  #12
UrSobsessed's Avatar
Originally Posted by UrSoccer_mobileĀ®
Is the fan sensor the one on the bottom left of the radiator?
Yes, that is the one that turns on the fan while the car is running. The one that turns on the after-run pump is located under the intake manifold screwed into the water manifold (the smaller one of the two that is closer to the radiator).
Old 04-13-2009, 10:24 PM
  #13
Jonny K's Avatar
Update - on further investigation I found the screw on cap on the coolant reservoir to be doing it's job poorly, so I'm pretty sure that's the culprit. I can't even tighten it, when I turn it tighter it'll keep snapping loose again. This is a new reservoir (and cap) to replace the old one which was broken, but I guess it's crap. Now I need to find a new cap (and possibly reservoir too).
Thanks for the help.
Old 04-14-2009, 03:25 AM
  #14
a4kquattro's Avatar
yep, that'll do it!
Old 04-14-2009, 04:18 AM
  #15
Junior Member
Julian_B's Avatar
make sure you get one at the dealer tho.
Old 04-14-2020, 12:45 AM
  #16
Fisher Mbakile's Avatar
What was the problem.?im experiencing the same with my Audi A4
MuRaN0Daddy
10-03-2005 09:48 PM
audipride87
Audi 100 / A6 (C4 Platform)
09-10-2005 10:56 AM
Arcteryx::Stock Rods
10-17-2004 11:55 AM
nosey
05-16-2003 09:11 AM
Crisqo09 T.O.
04-30-2003 07:26 AM
Quick Reply: Should my coolant boil?
