Simple AC question, at idle do your cars stay at a constant speed?
My idle will increase, then come back down to normal when AC is on. I think its always done it but im just not sure i thought id ask, TIA.
41/55-Signal from A/C control module -W/W - signal used by ECU to increase idle speed through ISV control when A/C compressor is activated (actually just maintains the idle seed when the extra load from A/C compressor is added to the system during idle)
so, im thinking its ok that it would increase, but is it normal to not just stay at the increased speed?<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/149829.phtml">https://forums.audiworld.com/s4s6/msgs/149829.phtml</a</li></ul>
It's a machine. Has to get a signal, process the signal, decide what to do and then send a signal to a device to modify the original input (takes time and the control amounts are not perfect) (basically a sophisticated trial and success method).
my idle has not dropped once, but it will burp every now and then up in RPMs, and i was wondering if the ac is magnifying whatever the cause is? or is the compressor reving the engine up 250 rpm's OK?
thermonuclear
09-19-2003 08:41 PM
RKA
06-23-2000 09:30 PM
