Snub mount
Snub mount
<center><img src="http://pictureposter.audiworld.com/87791/snub_mount_001.jpg"></center><p>At first sight it looks like jelly but it is "hard as a rock", to put it on it's place I had to use the press and some vaseline. The gap is reduced comparing to the original one but there is still about 10mm of play to each side(up/down). I supose that gap is necessary to reduce engine vibrations when the engine is not beeing pushed hard.
It's very easy...
First, you remove the two obvious bolts. Then you realize that there isn't enough room to get the thing out, so you look around and see the two (or three?) bolts holding the engine side of the mount to the engine block. You take those out, and realize you probably didn't need to take the two obvious bolts out at all.
But all in all it's really easy. It takes longer to get the car up and the belly pan off than it does to swap the snub mount.
Yes, I also removed the bracket first, but after banging it with...
...the rubber hammer(very hard) for several times, I quited. I was only lucky on the press and with the help of some esterylized vaseline, that I keep for another kind of jobs
