So I just pulled my codes finally...2111...what's the next logical step?
No start condition, when it last ran it ran great except toward the top at around 20 psi (MTM 1+) it would miss. Ignition switch is new so thats out, I could swear i don't hear the fuel pump prime though. Is that the next logical step?
2111 (Blink Fault Code), 00513 VAG1551/2 Fault Code Number
RPM sensor (G28)
Open or short circuit, sensor malfunction
Defective sensor & cables, metal fragments on flywheel teeth
Symptom: Engine will not start, misfires, may stop running
NOTE: I (Scott) have seen this fault code occur after cranking the engine during a no start condition
in a few rare cases where there was nothing wrong with the RPM sensor
RPM sensor (G28)
it gets a signal from the Cam Position Sensor (CPS).<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/149827.phtml">Link to FP Relay Function info in the FAQ</a></li></ul>
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/149828.phtml">Crank Position & Engine Speed Sensor Info - Function and Location Link</a></li></ul>
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/193829.phtml">Follow this three posting thread and link out to kday's data.</a></li></ul>
Crank position pins have been known to just fall off. Causes engine run/start failure. Need to pull the starter to check. (On a hoist or something so you can turn the wheels with the engine in gear).
See post link below for pin photo.<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/108072.phtml">Skollie's post re: location of crank position sensor pin.</a></li></ul>
adminisTerTurbo
Audi Original "S" Cars
11-26-2008 07:00 AM
BigMouse
04-21-2006 07:01 AM
Mitaka
02-07-2005 10:13 AM
