Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
so my car burns about 2.5-3 quarts every 5,000 miles on synthetic oil
Old 02-19-2006, 10:14 AM
spiralsmurf's Avatar
Default so my car burns about 2.5-3 quarts every 5,000 miles on synthetic oil
something about that, i don't like too much so I switched back to synth blend which doesn't get burned up. what do you guys think? is it normal to consume that much oil and even if it's consuming it then oil, is it still worth using full synthetic?
Old 02-19-2006, 10:19 AM
sk88erguy's Avatar
thats a good question. im about to use synthetic, what weight are u using?
Old 02-19-2006, 10:23 AM
Member
Only-Emre's Avatar
What grade synth. were you using?
Old 02-19-2006, 10:24 AM
AndreNY's Avatar
Default that should be normal...
i mean every turbo car even the new one's out of the factory will burn up oil, and i can also imagine u have a high milage S-car as well, so what you are burning is more then fine. BEfore my valve job i used to burn a quart ever 600 miles now a quart will last me till the next oil change which is usually 2200-2500 miles
Old 02-19-2006, 10:29 AM
Member
Only-Emre's Avatar
Default No way 2.5-3 quarts is normal or accapted in 5k miles.
KKK turbos are known to consume oil, yes, but anything over 2 quarts in 5k miles should be looked at carefully, or a differnt grade of oil should be used.
Old 02-19-2006, 10:31 AM
sk88erguy's Avatar
im thinking its the grade of oil as well, if it doesnt do it with the blend, i bet its too thin.
Old 02-19-2006, 11:07 AM
kday's Avatar
I've got about 4000 miles on M1 5W40 and there has been no noticeable consumption...
Old 02-19-2006, 11:42 AM
Default castrol syntec 10w-40. i was gonna try Rotella T synth 5W40 this time
but it said "Soot Control" which to me says...lots of detergents which will just make it burn more oil.
Old 02-19-2006, 11:43 AM
where do you find M1 5W40? I can only find Rotella T synth in 5W40
Old 02-19-2006, 11:44 AM
Default my car has 123,xxx which is pretty low for a 92. it also had the head rebuilt at about 80k
do you change your synthetic oil every 2500 miles? that's just a waste man.
Quick Reply: so my car burns about 2.5-3 quarts every 5,000 miles on synthetic oil
