Some greasy oil on this L-shape pipe.
<center><img src="http://pictureposter.audiworld.com/64237/img_4593.jpg"></center><p>I hate my car right now.after i've checked for the pressure leak.I've found out that there's some greasy on out from this L-shape pipe(on the back of the valve cover).and also look along the line i found 2 valves the bigger and smaller one.
also found some greasy on the hose connected to this 2 valves.I think that would be the PCV valves.So
1.Is that greasy oil caused from only the loosen clamp?
2.Is that also the caused of pressure leak?
3.Is this 2 PCV valves related with the pressure test procedure?Do i need to disconnect any hose before do the pressure test(In detail pls)?
4.How does the PCV functional?
So I need a lot help right now Pls..
Thank You a lot
POP K.
Thank You a lot
POP K.
My brother borrowed me a cam.btw
I would say that it's leak out from the pipe.
is this also the caused of boost leak?also got greasy on hose that connected to PCV.
may be i need to ask for the mechanic to reclimp on all clamp.
that we had to empty the catchcan after every stage.
before the catch can the car would push oil out of the oilpan
v8phil
03-16-2004 07:53 PM
tragopan86
11
03-11-2003 08:27 AM
