sunroof trouble
when the sunroof is in closed position, the driver sie of the sunroof is actually tilted inside the car... if i put hte sunroof position to tilt, only the passenger side will tilt up as normal, but the driver side barely tilts, making it uneven. and the sunroof does not slide back, i dont know if its of its track, if theres some sort of object block the track. the only other thing i can think of is its really cold outside and it maybe frozen(unlikely), and i may have messed something up with the track when cleaning the rear gutters...
in hindsight I could have just pulled the motor out and adjusted the cables to fix it. If you try this remember you have to be VERY CAREFUL to not let it get way out adjustment or time, its a delicate adjustment and you could really mess it up and break something. I would take the motor out with it shut and figure out which cable needs to be tightened to bring up the low side of the panel. When you pull out the motor maybe use a laundry marker to note where the cables are before you start messing with them. HTH's
Howie Feltersnatch
09-09-2002 01:09 PM
