Sunroof won't open all the way...
Try using the hex key to open it the rest of the way then use the switch to close it and see if it travels the full distance, I'm pretty sure it operates on some type of distance counter
the way, then hooked it back up and it closed only half way.There must be a distance counter that has failed.
Took the motor out, ran the motor with out the roof hooked to it, cycled it through a couple times, then lubed up the counter and the shaft. re-installed and now it works again. I think the counter got stuck ,there was a bunch of crap around the counter.
a6wag
Audi 100 / A6 (C4 Platform)
02-28-2009 04:50 AM
BigMouse
07-15-2005 08:02 PM
platypus_59
11
07-09-2004 04:10 AM
