Tach/RPM Wire Tap?
Anyone know what colored wire the tachometer wire is coming out of the ECU wiring harness? In the link below I can tell it is Pin #40 but that doesnt help me much..as far as I can tell?
Hooking up my Wideband A/F meter (Zeitronix)
However on the 200TQ 20V diagram is says #6 which is yellow/black?
cp<ul><li><a href="http://www.sjmautotechnik.com/trouble_shooting/20vpin.html#s4mot">http://www.sjmautotechnik.com/trouble_shooting/20vpin.html#s4mot</a</li></ul>
The easiest place to pick it up is on pin 1 of connector T6c in the passenger footwell. T6c is a green connector. You can see it here, behind the gray connector which has the MAP signal used by the TDS-1:
<img src="http://boost-instruments.com/wiring/both-boost-connectors.jpg">
The vehicle speed sensor is in the same green connector, pin 3, white/blue.
Bonus info:
Throttle position sensor is a gray wire going to the ECU.
Bonus info:
thecharlum
02-25-2010 05:18 PM
BLK01S4
04-22-2005 04:49 AM
scud
08-21-2003 10:54 PM
