Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
those with cone filters.
Old 01-05-2005, 07:38 PM
selfproclaimedv8buff's Avatar
Default those with cone filters.
i'm having a little problem and i'm checking everything so far on my car. I have a cone filter on it but from what i've heard, you can't just slap a cone filter straight onto the MAF b/c it'll create turbulence in the MAF. but doesn't the screen in the front of it do its job or is it too much? to solve the turbulence problem i've heard that adding some distance between the cone and the MAF will solve it. how long is the proper tubing to eliminate the turbulence?!
Old 01-05-2005, 08:02 PM
escargot's Avatar
Default Use a cone with a velocity stack...
<A HREF="http://store.summitracing.com/default.asp?target=esearch.asp&N=110&Ntk=KeywordSe arch&Ntt=akimoto&x=0&y=0">Like this</A>.
That's what I use. No screen. Works perfectly.
-Mike
Old 01-05-2005, 08:10 PM
which one specifically are you using ... AVC-?????
Old 01-05-2005, 09:48 PM
escargot's Avatar
Meh. I forget... I had a post about it here somewhere. Hold on...
Old 01-05-2005, 09:51 PM
escargot's Avatar
Default Here...
<A HREF="https://forums.audiworld.com/s4s6/msgs/21291.phtml">You are clicking</A>
Some of the pictures are different because they got replaced with other stuff.
-Mike
Old 01-06-2005, 05:37 AM
tpierce's Avatar
Default I've got a Dahlback intake
and it curves downward with the metal tube to give space before the mass air flow sensor. I've got my screens removed, have ran the setup for probably 6,000 miles or so, no problems at all.
Old 01-06-2005, 06:01 AM
so if i already have all the necessary equipment i can get away with buying just the velocity stack
Old 01-06-2005, 06:16 AM
Mr.FRU-T-Pants's Avatar
2nd
Old 01-06-2005, 07:04 AM
UR-Idiot Savant-S6's Avatar
3rd, but I kept the screens in.
Old 01-06-2005, 08:08 AM
EB_1920's Avatar
Aren't those things around $275?????
Quick Reply: those with cone filters.
