Timing question
Is it possible for a timing belt to slip enough to stall out an AAN and then prevent it from starting up again? And if i were to push on the timing belt how much if any slack should there be?
so #1 piston is at TDC. There are timing marks on the crank pulley, cam pulley and flywheel.
I'd expect the valves to be junk. Does it turn over? Sound like its got compression? I mean, its simple to check the timing belt's condition, line up the marks. You'll know in just a couple minutes whether that was your problem or not.
