Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
torque wrench(lpf ft) for AAN needed
Old 09-12-2006, 11:46 PM
popdemonic's Avatar
Default torque wrench(lpf ft) for AAN needed
my mechanic have just removed the AAN motor off.and finally,I got bad crankshaft from ex-mechanic mistake.So it need new crankshaft and connecting rod bearing.I havn't had any value on hand.pls let me know
Old 09-13-2006, 05:59 AM
S4-Fireblade's Avatar
Default It's getting bad and baaaaaad each time your "mechanic" touches your engine...
New crankshaft??????? Out off range to be machined???
My advice: buy a used engine from US! Cheaper than buying the parts you may need, plus people that are doing those jobs for you don't seem to have the skills to do it! Pop, you have really been unlucky with mechanics- I'm sorry for you.
Old 09-13-2006, 06:26 AM
urs6ick0's Avatar
Default Crank?
<center><img src="http://pictureposter.audiworld.com/113448/bottomend.jpg"></center><p>Pop, I have a known good used crank with 59,000 miles on it. All that needs to be done is polish and balance. I just tore apart a complete motor for rebuild.
Let me know.
Old 09-13-2006, 06:30 AM
UrS4boy's Avatar
Default Pop: You are being suckered left and right. You need a new mechanic. Cranks hardly ever go bad.
I can't imagine that yours is bad. Maybe a rod bearing but even that is hard to believe since your car isn't even chipped let alone equipped with a bigger turbo.
Old 09-13-2006, 08:38 AM
popdemonic's Avatar
Default I'm also have no any good word for myself :-(
<center><img src="http://pictureposter.audiworld.com/96144/image_00101.jpg"></center><p>
my motor has been changed the new rod bearing few months ago.
but i have no idea that why's it get bad(melted rod bearing) again.I've also asked the new mechanic about the cause.he said,may be "bad assembly"(that's why i need the torque wrench for the motor assembly) or "bad oil pump".I know that he don't want to blame my ex-mechanic.Now the crankshaft on the cyl#1(yellow circle)there're a lot of scratches.
Now I have checked the part no. from ETKA.
I found out that the crakshaft part no. for AAN
is 034 105 101 S.
that's the same part no. in AAR motor in A6,100.
but I'm just curious that ETKA shown that
A6(C4)AAR 1995 crankshaft part no .is 034 105 101S
A6(C4)AAR 1996 crankshaft part no .is 054 105 101
So how can the same motor has 2 differents on the crankshaft part no.? Can 054 105 101 applicable on AAN?
there're a plenty of AAR motors in the junkyard in my country with the good price.it would be my luck if it is applicable on AAN.
Old 09-13-2006, 09:06 AM
popdemonic's Avatar
Default not that easy dude...
Adriano,As i told you a long times that there's only few S-car in my country that still roll on my coutry road.There're a lot of difficulties
for using S-car.Parts availability,price(very very expensive),good mechanic,etc. I spent a lot $$$ for fixing my car.I'm tighten on $$ now.Importing the used AAN
from US.It was my idea.but it will cost me a lot.even not included tax and shipping yet.
the only way is.... how to fix my existed AAN to be
good again.hopefully,no more worse for me.
I'm looking for some used AAN motor as my spare(from some wrecked S-car).
and finally,if everything get worst.I will decide to sell my car or considering other used 2.4/2.8 V6 motor in the junkyard instead.
I've seen some S4 in my country came up with 1JZ-GTE motor from supra.it's rice but running pretty great.
Old 09-13-2006, 10:16 AM
spiralsmurf's Avatar
what is an AAR motor?
Old 09-13-2006, 10:21 AM
are you kidding? they put a supra motor into a UrS...thats a travisty.
Old 09-13-2006, 10:26 AM
UrS4boy's Avatar
2.3 L NA inline 5 (IIRC)
Old 09-13-2006, 02:03 PM
Default Well, prior to start fixing anything, you MUST diagnose the cause or the same may happen again!
- First of all, what was happening? Low oil pressure at idle or metal sounds coming from the engine- what made you disassemble the engine?
- Have you checked the other remainning 4 connecting rods?
- You said that it was your other mechanic's fault, so the engine had already been rebuilt(or at least someone tried to)?
- What did they replace, and why? Maybe they only replaced damaged parts and didn't go for the damaging cause(pherhaps some oil pump failure)??? Ask them or the last owner- you must know what happened before. It was no any torque(+ or -) that caused bearing failure! Maybe, of course maybe, he decided for the wrong bearing cap, or he assembled it wrongly and didn't notice- maybe it only that, but also your k24's turbos get worned out very quickly- don't you find it weard???
- What was your oil pressure at idle when you bought the car? As it been decreased latelly?
- The coolant level as been decreased?
- How are the spark plugs lookinn?
- Did you ever get the old turbos issues solved? For instance did you ever checked if there was oil pressure on the turbo inlet hose?
- When the other mech... disassembled the engine head some months ago where all the piston's tops reaching the top of the block?
Pop, you must be very sad, but in my oppinion, if you want to repair the car and keep it working you must concentrate yourself(fvck your mechanics oppinions- they don't stop doing **** with you and your car) and YOU MUST FIND YOURSELF THE CAUSE PRIOR TO START FIXING ANYTHING!
And please.... No supra's engines around!
Quick Reply: torque wrench(lpf ft) for AAN needed
