trunk lock problem 95 s6
the trunk wont unlock when all the other doors unlock. I can hear a long groan from the trunk but it never unlocks. When trying to use the key it doesnt always work and sometimes the key gets stuck. I thought there was tech article on how to rebuild them or replace but i couldnt find it. Anyone know any fixes for this problem ? thanks
Pete
Pete
Pete
Pete
You will have to open the trunk (somehow) and remove the inner panel (-watch out the clips near the window edge and the two hidden (painted) screws).
Once you have the panel off, you can see if the vacuum solenoid operating valve (item 4 in the diagram below) is properly connected to the vacuum hose (it might be still connected but leaking)
This operating valve should also be connected to the mechanical rod/linkage from the lock cylinder rod that trips the trunk latch. The rod might have come loose from a white plastic bushing that holds the rod to the operating valve, etc. If you have to rehab your lock cylinder you can use THIS procedure
big_anthoiny
02-14-2004 07:59 AM
