Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
turbo cooling pump!
Old 11-23-2003, 03:27 PM
New Member
zoltan's Avatar
Default turbo cooling pump!
hi guys!
im new to this group,i just purchased a 95 s6 with 131.000
miles.i was changeing the oil yesterday,and notice a coolant leak.it was coming from the turbo cooling pump.is there a casket?
anybody had this problem before?
thanks zoli
Old 11-23-2003, 06:01 PM
UrS4boy's Avatar
Default If you are talking about the electric pump under the intake manifold then....
you should first check to see if the clamps are tight (BUT NOTE: The pump is plastic and if you over tighten the clamps, you can break the pump). You should probably think about replacing the pump ASAP. If you have reasonable mechanical skills you can do it yourself. You can get a pump from the dealer but the price will likely be very high. You should try to locate one through an after market supplier like Blaufernugen (sp), etc.
Dave F.
Old 11-23-2003, 06:13 PM
New Member
quattropat's Avatar
Default Re: turbo cooling pump!
Happened to me,the two half housing that join together to form the pump have a rubber o-ring between them wich was leaking on mine.
Tried resealing it,too much pressure.
Pumps are expensive,I used one from an older generation VW VR6,same pump found for less money.
Old 11-23-2003, 07:41 PM
20VT90q's Avatar
Default Aux. Coolant Pump
Good advise, Blau is wayyyy over-priced though, go to the link below. I buy from them all the time. This is likely the cheapest you will find it anywhere.<ul><li><a href="http://catalog.eautopartscatalog.com/taylor/wizard.jsp?partner=taylor&amp;clientid=taylorautom otive&amp;baseurl=http://www.taylorautomotive.com/&amp;cookieid=13O1EGSUN&amp;year=1995&amp;make=AU& amp;model=S6--001&amp;category=G&amp;pa
Old 11-23-2003, 09:37 PM
AndrewWK's Avatar
Default Had mine replaced last week for the same problem
get it from thepartsbin.com for 94 bucks (bosch), versus 220 plus from the audi dealer.
AWK
Old 11-25-2003, 05:43 AM
cpayne's Avatar
Mine blew up in 2 pieces on the track...ended that day quickly w/o a spare easy to replace
Skribbs2000
02-01-2009 05:23 PM
Pushbutton_auto
10-26-2008 06:01 PM
AudiSpeed84
01-19-2008 08:02 PM
HOPSBurner
02-25-2004 11:58 AM
Bofett
Audi 100 / A6 (C4 Platform)
10-17-2002 03:13 PM
Quick Reply: turbo cooling pump!
