Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Turn signals don't work... Hazard button doesn't work. Any guesses? BTDT's?
Old 10-25-2008, 01:21 PM
AudiWorld Expert
quattro.pilot's Avatar
Default Turn signals don't work... Hazard button doesn't work. Any guesses? BTDT's?
I'm systematically going through and checking things out.. have looked @ wiring, grounds, Bentley, etc.. Everything seems to be in order but I'm hoping there isn't some weird link between the blinkers and maybe something else I've disconnected...it's the oddest thing. There's no secret relays hiding anywhere eh?
As far as I can tell it's the entire system, because the hazard button doesn't even work, though it does light up properly. Suggestions on where to poke around or something to check would be appreciated, as I'm getting down to the nitty-gritty on things I haven't yet looked at. I have a sneaky suspicion that there's a GND missing somewhere, so I'm about do to continuity checks at the hazard button.
Old 10-25-2008, 01:25 PM
kinderutz's Avatar
ignition switch ok?
Old 10-25-2008, 01:28 PM
Turbo_Anarchy's Avatar
Default I may be wrong but I think the turn signal flasher relay is part of the hazard switch.
We had a 2000 beetle in the shop this week with the hazards and turn signals out and it was the hazard switch causing the problem. Like I said I may be wrong but IIRC most VW/Audis incorporate the hazard switch and turn signal flasher together.
AudiWorld Expert
Default yea, brand new as of a couple months ago. I'm using the car as DD for now
but I hate not having signals... it's not a cool situation
Old 10-25-2008, 01:31 PM
AudiWorld Expert
Default yes, i agree with you. in the diagrams there's a hazard relay hiding somewhere...
so I think my next step is to locate that relay.
I have a sneaky suspicion that with the middle console area in pieces, some strange & unidentified ground hasn't been hooked up =S
Old 10-25-2008, 01:35 PM
Default But is'nt the relay part of the hazard switch?
I had the console out of Stephs Avant for her stereo but I don't recall any grounds in there to be disconnected to remove it.
Old 10-25-2008, 01:42 PM
AudiWorld Expert
maybe. it's a bit ambiguous but that's kinda what it seems to be..
Old 10-25-2008, 02:08 PM
Jonny K's Avatar
Yeah, the only time this happened to me was when my starter was engaged cuz of the ignition switch.
Brdman*'s Avatar
Default if you unplug the hazard light button, the singals won't work.
do you have a spare switch you can swap in?
Old 10-25-2008, 02:13 PM
AudiWorld Expert
Default i don't have a spare switch =( ... additional info: with the key out of the IGN
i can manipulate the hazard button which makes the SIEMMENS relay click.
doesn't make the SIEMMENS relay click if the ignition is at pre-start or anywhere in-between
Quick Reply: Turn signals don't work... Hazard button doesn't work. Any guesses? BTDT's?
